- 11 Dec 2008
- UK
Hello,
I am a "pro" Team Fortress 2 player and whether or not it helps my game-play I am used to it and like to play with a really high FPS.
I play at 640*480 resolution with an FPS Config (i.e. low graphical settings helping to maximise FPS and reduce visual clutter) using a CRT Monitor at 120 Hz. Ideally I would be looking to be able to maintain 120 FPS at all times. Currently I can go as high as 300 in a small room, but it can drop as low as 60(? maybe lower) in large open areas when there are lots of players alive and visible.
My current system is:
Core2 Duo E6300 overclocked to 3010 MHz
EVGA 7950 GT
OCZ 2GB PC2-6400 overclocked at 430 MHz
Gigabyte DS3P Rev 3.3 Motherboard
I was thinking I would be able to upgrade my processor and graphics card to achieve the desired result.
Any help and suggestions to possible upgrades would be really appreciated, if I missed any important information just say.
Many thanks,
nub
EVGA 7950 GT
Many thanks,
nub
