- 12 May 2011
- Southampton
I have the following gear in a naff cheapo case:
Sandy Pentium G870 3.1GHz CPU (@60c under load) on a 92mm Aidios cooler
2x2GB RAM
1x SSD
1x 3.5" HDD in same shelf (out of the way)
GTX 580 (@90c after 15 minutes of gaming)
As I've cleaned out the GPU and the CPU has recently been mounted and remounted, I think the problem is the lack of air and crap circulation in the case:
I think the CPU is warm as it is pulling the PSU air over it?
I think the GPU is warm because the inhale fan can't move enough air and is generally suffocating?
As the mobo is ITX it seems I can't mount the CPU cooler sideways.
How would you do the airflow in here? The GTX is a Frozr II cooler so not a blower designed one.
2x2GB RAM
1x SSD
