Morning everyone,
Ive got an issue with my new build well at least i think i do not sure..
Anyway my issue is the led on my motherboard slowly flashes like Every 2-3seconds funny thing is the system works perfectly fine i also checked the voltages cause i thought it was a voltage issue and those are fine too...
Only way i can make the led flash stop is if i take out my ram stick(only got 1 atm Its a budget build)
But the ram works fine i dont get it..
All the parts are brand new btw
The specs are
AMD Ryzen 5 1500x
ASUS Prime a320m-k
Antec VP 400watt psu
4GB Crucial ddr4
Those are all the brand new parts i also use my brothers old vid card and HDD but they work fine they just old
The vid card is a GeForce 650 GT
And 500gb SATA HDD.
I read online that flashing means something bad but like i said i can only make the led stop flashing if i take out my ram but the ram and system.works fine so im not sure what to do now...
Help?
Also im planning on upgrading my pc slowly this is just a budget/start So Its not like a gaming beast or anything
Edit:forgot to mention that it keeps flashing even after i shutdown the pc hmm weird and only does this when i use my ram if i power it on without any ram the led is then solid..
But i have no issues..
The specs are
AMD Ryzen 5 1500x
ASUS Prime a320m-k
4GB Crucial ddr4
And 500gb SATA HDD.
Help?
