Help me with my home network :)
26 Jul 2004
Hello everyone
Now then, I have had my network setup for a couple of years now. I have:
1 belkin 54g router (bag of do do)
2 belkin 54G access points.
All this for a standard 3 bedroom house :rolleyes: they are utter tosh. My laptop picks up 1 network to connect to, as They all use the same SID, channel and a WPA-PSK. I get initial connection issues all the time with all the machines in the building
I tried using different SID's for the access points. This gave me the chance to connect to each point. The access points didn't have any internet access, yet the router did
What is the best way to set this up, I am beginning to get a little lost, should they all be on the same SID? or not, is this causing an issue?
A quick step by step point on how this should theoretically should be done would be great. so basically showing me, how to have my network set up, SSID, Channel, MAC filtering etc. with a router and 2 cascading access points (to jump the signal to the other end of the house)
Thanks everyone, hope I can get this sussed.
hi, thanks both for replying.
The router, and access points were on the same channel, with the same SID, this gave me one main network to connect to. But i had a lot of connectivitiy issues with this.
depending on the current settings, I connect to the access points and router using an ip address, or by connecting them with ethernet.
so, in the router settings I can set it to act as an access point, to enable wireless bridging. then i enable it in the access points.
SHould the whole network have one SID and be on the same channel? how can i force it to work as one network :S
getting annoyed with this, considering jacking it in and buying a more up to date router
**edit, stupid question, yes my router does does this, so do all of the access points, they have the same admin page.
I have these headings under wireless bridging:
Enable wireless bridging (checkbox, which is checked)
Enable only specific wireless access points to connect (checkbox including space for multiple mac addresses)
Disable ability for wireless clients to connect (checkbox)
so that leaves me with the question, what should the SID and channel be? for the access points and route, same of dif
