Help me with my lost overclock please :)
I upped the qtt and even the dvid and the computer keeps giving me a bsod of whea uncontrollable error. :(. It was fine for so long yesterday..
try the settings when it lasted longer
you can set back to +0.0750v dvid if you want and just turn off c3,i think its down to enabling powersaving but you should get it stable
you might need more dvid,but temps wont let you add much more
mine used to work perfect with powersaving on
what bios you on now? I was on f12 I never bothered with f13
if those settings are the same as in your screenshots then cpu wouldn't have downclocked with ocuk settings,only when you set to normal cpu voltage then it will
