- 19 Feb 2015
Hi so all my parts were delivered today! Thanking you. Even threw in some Haribo for me
I'm stuck with the ATX Cable!
24 pin but 4 pins are separated, I can't plug in the 4 pin next to the 20 pin as some little plastic catches stop it from being plugged in all the way.
Is this normal or have I done something wrong?
Thanks in advance for your response!
