Following on from this thread: https://forums.overclockers.co.uk/threads/assembling-my-new-mobo-and-cpu.18886181/ - which shows what I am upgrading from and to.
My new mother board arrived + CPU + fan + RAM. I believe my old and new motherboards are both VPX, although my old one is just slightly shorter. But I checked to see if theh mobo fits in my case - it does fit nicely (I thought).
So I un-plumbed my old mother board (had to take out the GPU and water cooling fans etc) and got it out. Then started to test-fit my new motherboard. It goes into the case ok, but due to the way the old risers and back-plate (for eth, usb, hdmi, audio etc) line up, the bottom of my new board overlaps the power supply and so I cant get it in and lined up...
Here is a picture of my old/new board next to each other:
https://ibb.co/882m1J3
Here is a picture of the board inside the case - but not aligned with the screws or back plate:
https://ibb.co/JFxwrnn - you can see it fits in the box, but the PSU is in the way
, and the mobo needs to go more to the left - you can see the cutout at the back does not align (its a bit dark - its the greyish area just left of the silver eth/usb ports)
Here is my board held in the correct alignment, but the bottom 1-2cm is overlapping the PSU and so I cant drop it into place...
https://ibb.co/nC4t4wj
So now I need advice what I should do?
My tower is a nice large tower (not a mini or anything) so it should have just fitted. But then this is the first time I have changed a motherboard...
I think my options are:
- get a different motherboard
- get a different case
- re-work the case I have somehow
But I really hope there is an easier solution
