Hi all,
I have 2 leadtek 7800GTX in SLI and overclocked to 490/1320 they used to run fine 65-70 for the top card and 50-60 for the lower card under load, until today when I started noticing artifacts while playing NFSMW I checked the tempreturs in the nView panal and was shocked to see that the top card is running at 99 and the lower card is still at 50. I checked the fan and it was running. I'm worried what the summer heat will do to my rig so I started to consider fitting a VF900 or a Danger Den to water cool them but will they fit as I have a single PCI slot between the two cards. However if you have any other suggestions I would really appreciate them.
Thank you in advance..
long long time ago. It was hard enough to get those two now its even harder for me to justify getting a 7900GTX. Also I've never used the bay in my life
its a jungle out there....
I think that the cpu cant keep up with the cards at this clock.
then I will get some shiny copper from zalman
