help need cheap spec up
30 Nov 2005
hi have just bought a sn25p to stick my opteron and old bits in, now i would like to build a cheap c2d rig cheaper the better . I wan to OC the hell out of it by the way
hardware i have for it
x1800
600w psu
dvdrw
xfi extreme
lcd
spec me the rest .. oh i need 2gb ram
thx
sorry , um cheap as poss?
this look ok ?
Product Name Qty Price Line Total
OcUK 2GB (2x1GB) PC2-6400C5 800MHz DDR2 Dual Channel Kit £44.99
(£52.86) £44.99
(£52.86)
Gigabyte GA_965P_DS3 (Socket 775) PCI-Express DDR2 Motherboard £64.99
(£76.36) £64.99
(£76.36)
Intel Core 2 Duo E2140 "LGA775 Conroe" 1.60GHz (800FSB) - Retail £37.99
(£44.64) £37.99
(£44.64)
Akasa AK-ZEN-01-BK Zen Black Case - No PSU £25.99
(£30.54) £25.99
(£30.54)
Sub Total : £173.96
Shipping cost assumes delivery to UK Mainland with:
City Link Parcel Next Day (Delivered Mon-Fri)
(This can be changed during checkout) Shipping : £8.95
VAT is being charged at 17.5% VAT : £32.01
Total : £214.92
Yeah, also if your planning on overclocking, then I'd consider a aftermarket cpu cooler such as a ACF7 Pro, a very good budget cooler, you might also want to get the E2160 as it has a higher multiplier making it easier to overclock and only a few pounds more.
that MB oc well ?
650i Ultra does yeah :) Your layed out spec looks good too, although for the extra £3 I would just pick up the OCZ ram on this week only.
Yeah, but probably not as good as the P35 motherboard you chose.
It's the 965P one :)
what sort of clock should i get with that chip?
3Ghz ish I'd imagine, but may need an aftermarket cooler, even something cheap like a Freezer 7 Pro.
