CPU Intel Core i5-3570K 3.4GHz Quad-Core Processor £173.94
CPU Cooler Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler £25.18
Motherboard Asus P8Z77-V PRO ATX LGA1155 Motherboard £152.12
Memory Kingston HyperX 16GB (4 x 4GB) DDR3-1600 Memory £64.53
Hard Drive Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive £80.63
Case Corsair 650D ATX Mid Tower Case £136.38
Power Supply XFX 850W ATX12V / EPS12V Power Supply £99.98
Total: £732.76
I would like to have an overclocked cpu but I don't know whether to buy it overclocked or do it my self, and is it worth it to over clock because i heard it can shorten the lifespan drastically and as i said before i want a lasting pc for at least 5 years and if its normal can it run games just as well or much less well? Also i want a really good i5 core and i am willing to pay up to £250 and is the higher number version better than the lower number version of the 4digit cores? Also could anyone list the differences between the 3rd gen intel i5 and the 2nd Gen intel i5? If there are any things you would change please tell me. Thanks!
Total: £732.76
) if you SLI graphics card can you use just one monitor? Also what is the difference between the motherboard i listed and the one you listed. Also the board i listed is a pro, is that any better or is it the same as beejjacobs, i like the motherboard he linked me too but i still have no idea, i need more information if possible.
