help needed building first pc £350-400.
YOUR BASKET
1 x AMD A10-5800K Black Edition 3.80GHz (Socket FM2) APU Trinity Quad Core Processor (AD580KWOHJBOX) £95.99
1 x Intel 330 Series 120GB 2.5" SATA 6Gb/s Solid State Hard Drive - Retail £83.99
1 x Gigabyte F2A75M-D3H AMD A75 Chipset (Socket FM2) DDR3 Micro ATX Motherboard £69.98
1 x Western Digital Caviar Blue 500GB SATA 6Gb/s 16MB Cache - OEM (WD5000AAKX) £46.99
1 x GeIL EVO Leggera 8GB (2x4GB) DDR3 PC3-17000C11 2133MHz Dual Channel Kit (GEL38GB2133C11DC) £39.95
1 x OCZ CoreXtreme 500w '80 Plus' Power Supply £32.99
1 x Zalman T1 Mini Tower Case - Black ** OcUK Exclusive ** £21.98
1 x Samsung SH-224BB/BEBE 24x DVD±RW SATA ReWriter (Black) - OEM £11.99
Total : £416.46 (includes shipping : £10.50).
thanks fire fly.
can any one else add to this before i buy?
You may want to add a front fan, the case is not supplied with one.
http://www.overclockers.co.uk/showproduct.php?prodid=FG-038-BX&groupid=701&catid=2331&subcat=4
Also if you want to overclock that CPU to its best then you will want to include a CPU cooler, The CPU is supplied with a stock cooler that will be fine for normal use. If you do go for an aftermarket cooler then it will have to be less than 140mm in height.
http://www.zalman.com/eng/product/Product_Read.php?Idx=615
will look into them thanks,,,will order mon
will look into them thanks,,,will order mon so i neeg to get a fan controler
The motherboard has 3 fan headers, one for the CPU fan and two more for case fans.
The fan that I linked to is PWM so it will control its speed depending on the temperature of the case.
which aftermarket cooler is good?
Have tweaked the build to reflect the updated budget, gone with a larger case that will be easier to work with and a better quality PSU.
YOUR BASKET
1 x XFX Pro 450W Core Edition '80 Plus Bronze' Power Supply £43.99
1 x BitFenix Merc Alpha Gaming Case - Black £28.99
1 x BitFenix Spectre PWM 120mm Fan - Black £7.99
Total : £443.96 (includes shipping : £11.75).
Have not gone with a aftermarket heat sink as I don't think you will need it, out of the box performance should be good enough.
YOUR BASKET
thanks m8 looks good. do you think i need a fan controller?
I don't think you will need one, you only have 2 case fans and you can control them using the motherboard.
If you feel you want one at a later date then they are not hard to install.
