help needed for £1200 build
15 Jun 2016
hi need some help with parts
going to go i7 6800k
so need a x99 board going to overclock for the first time not much though just going to overclock to 4ghz
only going to get one card "gtx 1080" when they hit the shelves
so was think of one of them AIO water cpu coolers to cool cpu
and want 32gb ram not fussy on make as long as decent price
after a decent psu not sure what wattage though prefer a modular one
and a case to fit it all in,heard the gtx 1080's are quite long
ive got mouse keyboard,monitor ,hdd,ssd
thanks in advance!
Hi
Is this just a gaming pc ? Any video editing/rendering or game streaming ?
Any plans to SLI in the future ?
Also what is your monitor ?
hi yes
not going sli but will be getting a 4k monitor in a few months
mainly for gaming and a bit of video editing/music production
the monitor i have now is an dell ultrasharp 29inch wide screen 2500 x 1080p
and going VR as well
at the moment i have a athlon x6 1055t
asus rog crosshair1v
4gb ram
gtx 670
so its a bit off an old system
just wonder how fast this new build will be
You are going to struggle getting an i7 6800K and GTX 1080 unless you up the budget.
This Skylake build is just over £1200 with the cheapest GTX 1080 and 240mm AIO. As you plan on going 4K then you also have an SLI ready board/psu.
My basket at Overclockers UK:
Total: £1,211.89
(includes shipping: £0.00)
Same spec as above but with the i7 5820K/X99-SLI board:
Total: £1,315.88
hi lee32uk forgot to mention 1200£ is for cpu motherboard ram case and psu
got money saved for 1080 and htc vive
just gonna use my gtx 670 for the time being
thanks for the replys
That makes a difference then :)
If you are just gaming then you don't need 32GB Ram. A 4 x 4GB would do fine. The board has 8 Ram slots.
Also the i7 5820K is cheaper, but if you want to stick with the i7 6800K then do so. I went with the oem version as it is currently £20 cheaper than the retail version. The only difference is the warranty length AFAIK (oem is 1 yr and retail is 3yr)
The Phanteks Luxe will fit everything in it just fine. Check out other cases if you want something different though.
Total: £1,039.56
(includes shipping: £14.70)
yes that build looks good for £1000
case looks nice should be enough room for the cooler and slot for my new blu ray burner
thanks for your help lee ...might order it this friday when i get paid
