Hi,
I'm an avid PC Flight Simulator hobbyist and now need a new build for P3D and a search here didn't quite cut it. I've tried putting it together myself but lack the confidence.
I'm after a quiet running build and not interested in an RGB light show as it distracts from nighttime flying. All black would be great and for reasons I don't know, I'm drawn to Asus as a quality mobo manufacturer although I'm open to suggestions that don't detract from power, speed and quality. The P3D code base is FSX and CPU hungry.
Okay, must be: Intel CPU at least 4 cores, Cooling to suit, Mobo needs 4 USB ports if possible v2 is ok, 2 x SSD's - one for Win 10 Home OS and the other for the Sim so perhaps 250Mb and 1Tb? m2 spec not required, 16Mb fast memory, GTX 1080 8Mb - 1080Ti option not needed unless a necessary requirement for a 4k monitor, quite black case without unnessarry lighting and suitable PSU 750v?, cabling must be neat.
Budget around £1,500 to £1,800 if possible. Many thanks in advance.
