Help Needed for pfsense/Ubiquiti Build
Well done! It's a good feeling to see it all work :)
Yeah i have only ended up using 2 ports as one for wan then the other for lan.
I have a 24 port unmanaged switch on the lan then the AP and a few other things plugged into the switch.
Might have a second lan and use it for dedicated gaming yet... decisions decisions.
Other than that the OS is like hieroglyphs to me :)
Sounds good. I ended up getting a managed switch, and using the 2 ethernet ports on my pfsense machine bonded for a 2gbps link, and use vlans. I knew nothing about it all when I first started, my setup has definitely come quite far! Learning about tagged/untagged for vlans and trunk ports (HP procure switch). Its good fun to learn, and satisfying when it all works.
