- 1 Aug 2006
Hi guys I need some advice
I just built my PC after having loads of problems with another e-tailer and a faulty watercooler.
The PC spec is as follows
P4 805d
Asus p5wd2 premium
2x 1gb ddr2 667
1x 40gb ide hdd
2x 300gb sata2 hdd
1x dvd writer
512mb ati x1800xt
650w akasa psu
alphacool watercooling parts
and assorted case fans
The problem I am having is that the machine works but with no display at boot up, I get 1 long beep and then 3 short beeps from the bios (indicating a dead graphics card) but if I leave it I can hear the pc boot to windows but still get no display.
I purchased the card from overclockers and I had this problem when I first installed it so I arranged for a rma but after speaking to them the guy I spoke to was really helpful and gave me some pointers (fantastic service much better than the other e-tailers I have dealt with) and also explained that if the card was not faulty I would be charged £25 or so to return it to me (understandable really).
So I Decided to try and get it running and It did boot.
But now I have just reinstalled my watercooling kit after doing an external loop test to ensure no leaks and tried to fire the machine up and once again I get the long beep then 3 short beeps.
Should I assume this card is borked and rma it to overclockers or does anyone have any other suggestions for me.
I have tried the machine with nothing but the watercooler and graphics card connected I have also made sure all the power connectors are plugged into the mobo and card.
Thanks for your help in advance
P4 805d
Asus p5wd2 premium
2x 1gb ddr2 667
1x 40gb ide hdd
2x 300gb sata2 hdd
1x dvd writer
512mb ati x1800xt
650w akasa psu
