Hi i want to overclock my Cpu and ram, i have been looking into this for a while now. I will show you my spec then what ive managed to do.
2Ghz AMD X2 939 (Toledo), 2GB (2x1GB) of Ballistix Tracer's rated at max 250Mhz and a Sapphire Crossfire Board the top 939 board RD580.
I have had the pc now for 3 years and its still good on playing cod4+5 and Grid on full, but i want to give a small boost as the CPu is the slowest part.
Currently default setting's is Cpu 2000Mhz Ram 200Mhz and a HT@ 1000Mhz
I cant change the the CPU Multiplier it's locked at x10. My mulitiplier for HT is x5 and has options to change the speed.
The Ram has full configurations timing's and a speed select currently on 200Mhz Im not sure how to get the timing's correct for the speed.
Cpu only has speed select and voltage change
and the FSB has a few option's
my problem is the max i can set the CPU and ram is to 216x10 which leaves the FSB at it's max 1080Mhz i dont think i want to be going any higher. so i want to set it to 800Mhz then change the Cpu to say 2.4Ghz so the FSB will be like 960Mhz but i dont know how to set the correct Ram Speed's (timings) i was wandering if anyone could help me on this.
the current setting's are
200Mhz, FSB
RAM CPU/10
CL = 3.0
tRCD = 3
tRP = 3
tRAS = 8
tRC = 11
CR = 2T
Dram idle Timer 16clocks
200Mhz, FSB
RAM CPU/10 CL = 3.0
tRCD = 3
tRP = 3
tRAS = 8
tRC = 11
CR = 2T
It just freezes everytime. the ram has only set value's on Memclock 250Mhz and then it goes down to 233Mhz and bellow. I wouldnt be ablle to get 240, thats if it has to be the same as the cpu??? it just ent happening. I hate this sapphire Motherboard nothing ever works on it
