Help Needed Please Overclock
28 Jan 2007
Hi All
Ive built a new system and ive seen many nice overclocks with simular , but for some reason ive hit a wall at about 2.64 (about 240 x 11). It's stable at 2.56 (236 x 11 ) and the cpu temp is 36 deg on full load .
I will list my systems and if anyone has got a simular set please give me some pointers as im new to this type of bios.
Cooling is no problem i just want to get the most i can out of it.
Step by step would be fantastic
Thanks in advance
Amd opteron 175 (2.2) 939 OSA175DAA6CD CCBWE 0551VPMW (cpu stepping code)
Asus A8N32 sli deluxe
2 Gig Patriot EP DDR 500
Sli Gforce 7800 gtx
2 x 160 maxtor HD
using onboard sound as no room for sound card
Psu Jeantech Storm 700W
ok so far im stable @ 11 x 250 ( temp = 42 Deg full load torture test)
pc prob says its running at 1.58 volts but i set it in bios at 1.4 (anyone know why this is)
can anyone give me some advise on getting more from it.
would dropping multi to 10 and putting fsb up help ??
Thanks in advance
36degress full load ?
What you using for cooling ? Water ?
My 4800 is at 2.75ish on water and temps are 30 idle 44-46 load , mine hits a wall around 2.8 but thats on 1.5v(the boards max :( ) wish I had more(I might volt mod it yet if can be ar*ed.
Have u tried cpuz and checked voltages there instead of pc prob ?
I would think to get over 2.7 you would need more than 1.4v but you do need to verify that voltage before going any further.
Thanks for reply , Im using titan amanda Tec cooling
ill download that program you said and give it a try..
Ill post back results
PC probe is pants, use Coretemp for monitoring temperatures. Most software i.e PC Probe, Speedfan, CPUZ will report a vcore that varies quite a lot. As long as it's not set as 'Auto' in the bios, you'll be fine.
Thanks for info .
Ill try look for some info on what voltage is safe to use 24/7
