help needed please
23 Nov 2013
Hi guys I just installed a new SSD as my primary drive, put windows 7 on and booted up. After reconnecting my 2 old drives 1 installed just fine ( old primary one ) but my second bigger drive with all the stuff i actually want is showing as unallocated etc.
im sure its something quite simple as its not very old and deffo not damaged but i really would like to get the data from this ( 350 or so Gb of stuff i actually want/need )
HELP!!!!
currenty running minitools partition wizard and its been going for an hour and not even got to 1% yet! im sure its a simple thing im missing but the other drive just installed drivers and popped up like std autoplay, scanned the disk and sorted itself out in minutes.
cheers
Jeff
Have you made sure the drive is connected back into the same SATA port on the motherboard?
Anyway you could have accidentally formatted the HDD during install/before?
Just something simple. When booted you may have installed the drive but you may still have to take ownership when moving or copying data. This is the reason a backup is restored so much quicker because paths and permissions are of the ame Admin phase.
