- 21 Mar 2023
- Scotland
Purchased a 5800x3d and now I have no display.
Currently upgraded from a 5600 to the 5800x3d with gigabyte x570s 32gn 3600 Corsair pro ram and a 4070.
New CPU yesterday arrived. Started by updating the bios to f6b then undone the MSI mag 360 cooler and installed the CPU. Cleaned the CPU cooler and fitted it with mx4 paste then booted up the pc
Couple of mins went by and nothing so I unplugged the power cable, removed the CMOS battery and used the clr CMOS jumper to reset the bios.
Switched back on and was greeted with the new CPU Installed select y to continue. Then came the gigabyte splash screen press f12 for boot menu etc then it went black again and now no matter how many times I try I don't get a display ( monitors are receiving a signal I believe as they don't go into sleep mode )
Stuck where to go next. Any suggestions.
Should have noted I have no bios led lights on my board but I have unplugged all the usbs etc
