- 21 Mar 2023
- Scotland
I don't think it's a bios failure but I did reflash it after u mentioned it. I don't think it's the bios as you can still hear the sounds when it loads into windowsWell you’ve confirmed the gpu and cpus are working by trying them in your sons pc. You’ve tried known working parts in your pc with the same no display outcome. Seems to me the motherboard has popped it’s clogs or the bios update failed. Does your mobo have a dual bios? Does it allows usb flashback?
