help needed please
20 Oct 2002
Oxfordshire / Bucks
Internet is now crap and slow, please read on...
When we are on Plusnet the configuration was as follows:
Router upstairs in my room
My PC is connected via wire
i have another wired cable heading downstairs "outside" into the office downstairs
I also have another PC connected to my router, but this is via the electrical socket via some Tp-link Home plugs (i didn't buy this)
we also have yet another TP-link Home plug connected (via electrical socket) in the living room for the SKY / TV
CURRENT CONFIGURATION IS AS FOLLOWS:
We now have been switched over to Sky broadband
So what someone has done whilst I was at work, is connect the Sky Router into the phone socket DOWNSTAIRS
Unplugged the cable that went into the back of the office PC downstairs that was connected to the router upstairs
So now the office computer is now connected into the SKY router and the rest is still the same above
Now my PC upstairs is so slow that websites don’t load sometimes (ocuk forums seems unaffected?)
What can I do ?
I would like to take the sky router out personally, but that’s not an option at this time
What I’m thinking:
Plug in a cable that goes up stairs into the sky router
Reconfigure the Nettgear router to talk to the sky router better
And then I can move the home plugs to the sky router away from my netgear upstairs
I don’t understand how it is all working (even barely)
Basically I am seeing one phone line downstairs, Sky router is plugged into that, 1 PC is connected to it
2nd phone line upstairs connects to my netgear router that is connected to my PC and also connects to 1 home plug (with a 3rd home plug connected to sky)
diagrams would help ?
so what can I do ?
Thanks
A diagram would help, yes.
What was your expected speed? Have you tried any troubleshooting on the sky help website?
Why do you have two routers?
Hope you can see this
Yeah 2 routers here is sounding like a bit of headache. Don't quite understand why. Surely Sky Router downstairs. And then just homeplugs in the other rooms? Or failing that a switch upstairs?
Not sure why your netgear router is plugged into an upstairs phoneline? Not that it should make any difference
Looks like your router is connected via homeplug to downstairs? but where does either of the downstairs homeplug units connect back to the router?
Ideally you want your router to be set into access point only mode if possible, if not it needs replacing with a wireless access point/range extender that has multiple ethernet ports (or a separate gigabit switch and access point).
there is a homeplug connected to it, thats for my dad in the 2nd room to get emails and the like on his PC
