- 25 Nov 2006
- Ipswich, Suffolk
Hello,
Got a bit of a query over white balance. Well, I think it’s a white balance issue I have with my new camera (most likely not setting it correctly!)
I take a lot of product shots for my ebay business using a light tent and 2x50w halogen spotlights and I can’t seem to get a nice crisp white background. I thought my new camera would manage it easily, but perhaps there is something I’m not doing?
I line the images up, set the white balance so everything looks nice and white on the camera’s LCD. I set the metering to Multi, aperture and shutter speed are set to auto and turn the flash off. I then take the picture and it looks OK.
When I get the image onto the PC, it looks dull and the white background is either gray or slightly yellow. I then got into Photoshop Elements and use the Auto Colour Correction option and the picture then looks how I want it and how it looked on the LCD.
Could it be a white balance issue (me choosing the wrong one). Could it be the lights I’m using? Maybe it’s a colour profile thing? Or am I just not using the correct camera settings? Or could it be because another light is usually on in the room and upsetting the camera’s white balance?
Any help or advice would be appreciated.
but it has roughly the correct greyscale level) in manual exposure mode and you should find that your background will be no longer grey. This tip is also very helpful to correctly expose snowscapes or similar scenes.
