- 9 Dec 2009
- Bristol
So I've had a new clutch put in the focus (mk1 facelift) and have decided to keep it a while longer, so in the meantime I've decided to do some modding:
Now before people start calling me crazy, I know I should have had a heavy duty clutch fitted to handle the extra power rather than the standard replacement but I'll bear that responsibility.
I'm putting it down in the little tray at the bottom of the centre console and don't know where to route the probe wire to the exterior for the outside temperature. Apparently the best place is inside the front bumper but where do I route the wire? How about down through where the gearstick goes? If I pull up the leather gaiter at the bottom of the gearstick there is a hole.
I don't want wires everywhere, I've fitted car stereos many times before but not had to wire anything from the interior to the exterior so some help will be appreciated.
Thanks
Thanks
