Background:-
Basically i feel that its time to update my rather noisy system, i am confident enought to build a system, but i havent really kept my eye on the scene so dont really know which components are compatible with one another anymore.
At the minute i play world of warcraft and UT, i do a lot of downloading and disk writing etc, but all my files are kept on a 300Gb external hard drive, so i dont need to worry about actual storage space in the new spec.
My current system is as follows -
Jeantech Aqua Midi Atx Case
Intel 630 LGA775
ASROCK775VM800 Motherboard
XFX 7800XT 256Mb DDR3 AGP
2x 1Gb DDR400
Antec 500w power supply
2x 80Gb IDE Maxtor Hard Drives
1x LG DVD Rewriter (Crap)
20" Acer Monitor
I'm more than happy to keep the case and Monitor, but i feel that everything else needs to go.
I am running XP Pro at the minute and would prefer to stick with that if possible.
Obviously the idea is to keep the prices down as much as possible as i am on a £350 ish budget.
Oh and i should also say that the system needs to be as quiet as is possible, the current system sounds like the main runway at heathrow, and the wife is about at her wits end with the constant drone (especially as the system is in the lounge!)
Intel 630 LGA775
2x 1Gb DDR400
20" Acer Monitor
