Help needed with PC build.
2 Feb 2015
Northern Ireland
Hi guys. a colleague who knows about pc's built me one a few years ago. it worked really well but I didn't take good care of it and I thought I would start upgrading it a little. in my ignorance I went and bought a new processor, checked it had the same socket and it was the same make as the old one, AMD. when I installed though it wouldn't boot up, it then hit me it probably doesn't work with my old motherboard.
old pc parts list.
1 LG GH22NS50 22x Internal DVD±R/RW Drive - Black (Retail)
1 Samsung HD322HJ SpinPoint F1 320GB SATA-II 3.5" Hard Drive
1 Arianet 1001 Black Gaming Case, 3 Temp LCD Displays (No PSU)
1 Arianet Black 800W "High Efficiency Gaming PSU" ATX Power Supply for AMD and Intel Motherboards 20Pin + 4Pin
1 Windows 7 Home Premium SP1 64-Bit DVD - OEM [GFC-02733]
1 Asus M4A79XTD Evo AMD 790X (Socket AM3) DDR3 PCI-Express Motherboard
1 AMD Phenom II X4 965 Black Edition C3 3.40GHz (Socket AM3) Processor - Retail
2 Sapphire ATI Radeon HD 5670 1024MB GDDR5 PCI-Express Graphics Card
2 G.Skill RipJaw 4GB (2x2GB) DDR3 PC3-10666C8 1333MHz Dual Channel Kit
all the parts are now old and its hard to find them on sites so I cant find links unfortunately. the new processor I bought was
1 AMD (Piledriver) FX-4350 4.20GHz (4.30GHz Turbo) Socket AM3+ 4-Core Processor - Retail £ 59.95 £ 59.95
Basically I am just looking for someone to suggest other parts that will work with the processor I bought. I don't mind buying new parts and building up a new pc. I am looking for a decent gaming machine at the end of it.
any help or suggestions anyone can give me would be greatly appreciated. thanks for reading. Edit = typos and tidy up
What budget do you have in mind?
If just for gaming, an overclock to 3.8 or 4.0Ghz plus a better graphics card would be reasonable, possibly more ram.
http://www.overclockers.co.uk/showproduct.php?prodid=GX-169-PC&groupid=701&catid=56&subcat=1982
A budget mobo would be the following, but I feel that the processor you have bought would not be much better than the one you had.
http://www.overclockers.co.uk/showproduct.php?prodid=MB-501-AS&groupid=701&catid=1903&subcat=2046
thanks for the reply. so if I bought the motherboard and graphics card you suggested they would be compatible with what I've currently got?
I wouldn't use that cheap PSU to run even a single 290X. And no chance of running two. It's not a "true" 800W, and only brings 2 x 6-pins for GPU. Dual 12v rails of only 15 Amps each, according to the little info I've found.
PSU is the first thing I'd be replacing if you're getting a new GPU, unless you get something like a 260X or 750Ti.
