help needed, XFX ATI 7950 DD issue *SOLVED
Hey,
My ATI card is probably dying but i wanted to run it past you guys in case there is anything i can do.
The stock speeds are GPU 800mhz, Mem clock 1250mhz and this is on an 800w PSU
At this setting after a while my pc locks up with vertical lines, usually when playing a game or using Youtube.
Within CCC i increased the power control setting to 10%, then 20%, both gave same results.
I tried a fairly large leap and took down the clocks from 800/1250 to 500/750!
since I did this i have not noticed the crash, only when i put it back to stock, i'm not very good with this sort of thing but obviously running the card at half specs is not ideal.
is there anything i can do, is the card not getting enough power at stock setting or is it time to change cards?
cheers in advance
Hey,
cheers in advance
but before jumping to conclusions .....
