Hi there,
I have just bought a new PC and it works fine.
However, when I hook it up to my current monitor I see the boot screen and Windows loading screen, then it goes black and says "Out of Range".
I have looked around on the web and found that using safe mode to alter the resolution should fix it, but I still get the "Out of Range" message after the Windows loading screen.
It worked fine in the shop and also when I hooked it up to my TV.
Does anyone have any suggestions as to the problem?
