Help Needed.
Man of Honour
23 Mar 2011
West Side
My sons computer wont boot , when you press the power button all the fans pulse twice then nothing.
Checked all connections, disconnected all power cables and rerouted them and tried a single stick of ram individually.
Got a Feeling its the PSU . Thoughts ?
Sounds a lot like a PSU problem. Can you hook your own up, see if that fixes the problem?
Does the CPU fan run? Some motherboards shutdown if a rotating CPU fan is not detected which can usually be disabled in the BIOS.
Are there any audible beeps on startup?
