HELP :: New G.Skill Zx Ram problem!
4 Aug 2005
Ok guys just received my G.skill 2*1gb pc3200 zx kit and popped them in my system and for some reason they won't run on a divider above 140 but will run stock timings. I have tried on a 166 divider with slacker timings and upping volts to 2.9v and still no joy (doesn't even get to windows loading screen). I put my 2*512mb pc3200 ocz gold's in and i can run 180 dividers lol with the same cpu clock (260mhz*10).
Anyone have any ideas? or is it rma time for the ram?
k i'l give it a go when i get home from work this afternoon and let you know how it goes! just find it strange that it will run the timings just doesn't like the 166/180 dividers but with cpu running at stock (200*10) it will run on a 200 divider
I can only run the 133 & 166 dividers. Whether thats down the the mem, the mobo/bios or the optys mem controller i dont know but fortunately 133/166 is all i need so i've not investigated further. As trojan says tho i'd certainly try lower volts, the best results i've had have been at 2.6/2.7v (currently 208mhz 2 3 2 5 2.6v 166 divider, orange slots, 623 bios)
I found my set of OCZ 3200 Plat and G.Skill ZX kits liked different dividers. Again, not sure if this is memory or on-die memory controller.
I stuck with the G.Skill in the end as it worked on a convenient divider (see sig).
I also had some weirdness whereby I couldn't use a divider when the memory was set to 2-3-2 timings, even when it was ~ 200 Mhz. Again, see sig for the timings I used in the end. I'm convinced this is all due to the on-die memory controller when overclocking hard.
I agree with other people - they don't like high volts. 2.7 was sweet spot for me. 2.8 and higher just errored.
rite-o i think my g.skill is nackered! i just reset cmos and tried putting the ram on a divider of 200 with stock timings (2-3-2-5) and the cpu at it's stock 200*10 setting, every time i would get to windows loading screen and just before it's about to come to desktop it reboots! i then popped my OCZ back in and it boots up fine. Anyone else think this is RMA time?
Doesn't sound good. Leave everything at stock and run memtest for a few hours.
ok guys update for you here! i re-flashed my bios (to the latest) and now ram is working on a 166 and 180 divider. However boot times are getting a tad silly, i currently have my ram running on the 166 divider and 2.5-3-3-8 and 216mhz now my comp gets to my windows sign on screen quickly but after i enter my password it takes ages to get to desktop (First my background appears, then eventually my desktop appears).
