help new rig keeps crashing in games?
9 Nov 2013
hi all I have recently built a new rig and for some reason my games keep crashing. some times I can play for a good half hour then it happens I start task manager and it just comes up the games not responding. any suggestions on what the problem could be?
windows 7 64bit asus maximus formula v z77 3770k xspc raystorm water block xspc reservoir and pump 16gb ram Kingston hyperbeast x 2400mhz 4x4gb 2x gainward gtx670 Kingston 120gb ssd and standard 1tb drive for games and a corsair ax860 power supply its so disappointing because when I do get my half hour go an bf3 it looks so good.
Full system specs please :)
windows 7 64bit asus maximus formula v z77 3770k xspc raystorm water block xspc reservoir and pump 16gb ram Kingston hyperbeast x 2400mhz 4x4gb 2x gainward gtx670 Kingston 120gb ssd and standard 1tb drive for games and a corsair ax860 power supply its so disappointing because when I do get my half hour go an bf3 it looks so good. :mad:
Couple of things that you can check / do:
Test with only one GPU installed.
Also are you overclcoked at all on the cpu?
Double check your memory voltage and timings.
yeah I tested both separately and they work. yes I used the autoclock feature that came with the motherboard up to 4.4ghz
memory voltage and timings I don't have a clue totally new to pcs just wanted a nice gaming rig.
Try running at stock, auto overclock features are fairly hit and miss, your best bet is to look around for tutorials on overclocking your cpu.
Auto overclock on my Asus Z87 board is very hit or miss. It either applies too much or too little voltage. My guess is that it applies too little vcore. It is always best to overclock manually. There is always someone on here to help you overclock manually.
most likely a setting
did you want to clock to 4.4ghz? and did you enable xmp for your memory?
well yeah I thought overclocking would give me a few more frames but would rather have it running smoothly for now I reset the setting in bios but my ram only read as 1333mhz when I put it on 2400mhz windows wont load.
For 4.4ghz you could try medium loadline calibration,+0.015v CPU offset,manually set the CPU multiplier to 44x,and the pci/cpu clock to 100
Set dram voltage to 1.65v and system memory multiplier (ram) to 2400mhz might need 1.10v vtt voltage also might be called vccio or vccsa,whatever its called it will be stock 1.05v
currently its like this vccsa0.961v vccio 1.059v also got a second vccio voltage at 1.050v
Can you adjust both vccio? I would just change the stock 1.05v one to 1.10v (may need more for 2400mhz) but try 1.10v for now,max safe is 1.2v but doubt you'd need that much
Could be memory,2400mhz is hard to setup
Try the same settings but try with ram at 2133mhz then tweak it from there
Edit:just realised you have 16gb of ram,I doubt you'd manage 2400mhz or even 2133mhz with 16gb on ivy
Start at 1800mhz then take it from there
what 1800mhz with dram voltage 1.65v vccio 1.10v yeah didn't realise it would be like this to set up I just got the ram because I got it in a sale and I think my mobo said it supports ram up to 2600oc I think maybe even 2800oc
