Help: No display from Computer
12 Jun 2009
Tun. Wells, Kent
Hi,
Yesterday I was having problems with my LAN network adapter, which was not showing up on my computer, because I think it was in deep sleep mode. I read that this problem could be fixed by removing the RAM and replacing it after a few minutes. After doing this however, when I turned my computer back on nothing was outputted to the display. Additionally the power button will only turn the computer on not off, I have to turn the power off on the PSU.
Since then I have reset the BIOS with the jumper but it has not fixed the problem.
I have also noticed that when turn the system on and run it with no RAM the motherboard does not bleep as I have read it is supposed to.
The keyboard is also not powered.
Any help to fix this problem would be very much appreciated,
thanks.
Computer hardware:
GeForce GTX 460 768MB Graphics Card
Asus M4A87TD/USB3 AMD 870 (Socket AM3) DDR3 Motherboard
OCZ Reaper Low-Latency 4GB (2x2GB) DDR3 PC3-12800C6 1600MHz Dual-Channel
AMD Athlon II X4 Quad Core 635 2.90GHz (Socket AM3)
Be Quiet! Straight Power E7 600W Power Supply
