Help! No display with hdmi connector hanns-G
21 May 2008
Hi guys, I have just bought the Hanns-G 28" widescreen monitor to use with my geforce 8600gt. I am having a problem getting the monitor displaying anything when loaded into windows when using the dvi -hdmi connector provided.
I am using Windows XP sp3 and have tried the 175.70 nvidia drivers as well as the latest 177.79 ones and both give the same result.
On bootup the monitor displays the bios and loading screen but as soon as windows has loaded when it changes from the logo to your display i just get a black screen.
Any help or suggestions would be gratefully received.
Thanks a lot
Yamahayoda is online now Report Post View trust for
Installed the nvidia drivers for the HDMI interface first? also why not use dvi instead?
the monitor only has vga input and hdmi input, the graphics card has 2 x dvi outputs and a tv output. I am using the provided dvi (graphics card side) to hsmi (monitor side) cable as i want a digital signal otherwise the quality is rather poor to say the least with a monitor this size running of an analogue signal.
I have tried a number of drivers from *** nvidia site, working my way down from the 177.* am now to 162.* and with the 16* series of drivers i am now getting block fuzzy colours that fills the screen for about 3 seconds then dissapears only to reappear a few seconds later. I continues this cycle.
I am assuming its a driver issue and you have mentioned installing the hdmi interface drivers. Are these seperate drivers from *** graphics card drivers? and if so where would i get them from?
Thank you for your response and if you think of anything else please let me know
Cheers
The latest whql from nvidia should be fine really, my old man uses hdmi on his 8500gt but his card has a dedicated hdmi socket and dvi so doesn't need to use the adapter :/
HDMI to DVI should be fine as it's exactly the same protocol over a different plug. What this sounds like is the Hanns.G not letting the OS know what resolutions etc. it supports and the computer sending out something it can't handle.
I would recommend plugging an old monitor in, booting up, putting the res at 800x600 and 60hz then shutdown, swap monitors and try booting again.
Just tried what you suggested philjohn to no avail. Its still pulling up th eblock colours every 3 seconds but after its done this 3 times it flickers to the display for a split second then back to the colours.
I am baffles as to why it owuld be doing this and i really dont want to have to go out and buy a dedicated hdmi output card as i have only just bought this one i am using.
I have tried loads of drivers and whats baffling me the most is that when windows is using the standard vga drivers it works with the dvi-hdmi cable!! but obviously the screen draw rate is useless and i am imagining gaming would be a joke.
I am at a loss as to what to try next
Can you try it on another computer? Could a friend bring one round? If that displays the same problem it's the monitor. Getting HDMI out is of no use, DVI and HDMI are exactly the same just with different plugs (well, and HDMI does audio, but that's nothing to do with the video side of things)
cannot get another computer to try it on but like i said before it works fine in safe mode and without drivers loaded. I am wondering if this is a driver/card/monitor incompatability that can only be solved by changing the graphics card to a less "cheap" one as i susspect Xpert Vision aren't one of the 'upper' graded makers of video components but i don't really know, am just clutching at straws now
Xpert Vision may be cheap, but the cards roll off the same production line as the more expensive ones and are identical apart from a sticker. Wish I had something to suggest, don't suppose you got any monitor drivers with the monitor? The only way to find out if the monitor is faulty though is to try it on another PC.
If you've got another monitor you could setup dual screen and then at least you can try setting the new screen to various modes to see if you can get it working.
have tried setting it up in dual mode with my old 19" lcd and still no joy. works great with the vga connector but not at all with the hdmi. tried reinstalling the latest 179.79 drivers and still no joy. seems odd that it doesn't have any problems in safe mode or with no drivers installed.
