Help no input signal!
19 Apr 2010
Hi I had a friend put a pc together i'd bought but when I plug the monitor in I get no signal iv tried another monitor and it's the same, is it because I don't have the drivers for the motherboard and no operating system either??? urgent advice appreciated.
Even with no drivers the BIOS screen will display on the screen.
When you press the power button do the fans spin and lights illuminate on the motherboard and case?
yes fans lights DVD drive opens when I had a pc a long time ago I remember the little blue monitor slot fitting into a seperate adapter that fitted on the back of the pc could I need one of those?
If you are using a discrete graphics card, is the PCIe power cable(s) connected to it from the PSU?
Would you be able to post up a few photos of the motherboard connections so we can ensure that all the connections are correct?
Also, were stand-offs used to mount the motherboard to the case and were any excess ones removed?
Finally, can you post up a full spec of your new system so we know what you are working with?
If the sytem has a discrete card, and a VGA port on the motherboard, make sure the screen is connected to the GPU instead, as the motherboard port will be disabled.
I can do the photos tommorow I don't really know what he did it's a biostar 78oa or sumin motherboard with an amd dual core 3ghz ati radeon 5770 1gb 4gb ram 600wat psu 640gb hardrive the small blue port is the only thing the monitor fits in there is a bigger White version and two red versions on the graphics card
gpu??? the only slot that fits is where the motherboard is if gpu is graphics card the slots are slightly bigger and thus the monitor won't fit appreciate your help guys
Can I just confirm:
- You have a VGA monitor
- There are no VGA connections on the graphics card
- You connected the monitor cable to the VGA connection on the motherboard
Is this accurate?
Try plugging it into the Mobo graphics port and turn on, and if you have a 2nd screen put one on each and restart. He may have accidentally set the to the wrong primary/secondary settings.
Have you pluged you monitor directly into the graphics card or the built in graphics port on the motherboard?
Is it possible to plug your current monitor into your graphics card? Your friend has probably set that to the #1 output for displays.
GPU = Graphics Processing unit. GPU is used as shorthand for Graphics card as it is much faster to type.
If you can't connect the monitor to the graphics card (is the cable too short?) then do this:
-Turn off the PC
- Remove the graphics card power connection
- Remove teh graphics card from the PCIe slot (there may be a little plastic tab on the slot you have to press down to release it)
- Store the graphics card (GPU) somewhere safe
- Connect the VGA cable to the port on the motherboard
- Try turning on the PC on again.
The reason that there is no monitor signal is because the motherboard thinks that the display signal will be required from the graphics card it detects is plugged in -so it disables the basic GPU that is on the motherboard (hence you get no picture). To get picture you either need to get a DVI to VGA adapter (hopefully should have come with the graphics card - or can be bought from an electronics shop) and plug in the monitor to the GPU through this, or remove the graphics card (temporarily until you can get one of these adapters) and make use of the motherboard GPU.
Make sense?
no because it won't fit the slots on the gfx are two big I need to go out now but I'm going to ask a friend if he has an adapter to try that will make it fit and il be back on at half ten, thanks
-Turn off the PC
What he said.. Before me >. >
Edit: I think he means he has the wrong cable type not length, as in the connector is the wrong size to fit into the hole (lol).
