- 5 Aug 2006
- Derbyshire
But failing after 30 mins is no good so make sure it's stable. I'd try running small fft's to see if that fails first (or drop the cpu multiplier way down and run blend) to see for sure if it's the cpu that isn't stable.
I just meant that he isn't a far off stable if it passes 30 mins in. Another cpu colt notch after than would probs mean failure after 4 hours.
