Them screenshots show you at 2.55ghz not 3.8 (orthos will show 3.8 as it dosn't work with multi's - it just assumes its on the highest one iirc). Set the multi in the bios to 9 rather than AUTO to be sure. You might also want to consider stress testing with 'blend' which will test your whole system rather than just the cpu for stability once you have the cpu stable. This will stress cache, memory, cpu & memory controller.
You may also want to change the 'lady' to laddy' - that is unless you are a female of the species
