- 13 Apr 2021
My first post...
I received an Oculus Quest 2 as a gift. As a cynical (and slightly geriatric) PC gamer I didn't expect much from it but was blown away by the value and fun of it all.
I've caught the bug a bit and want to use my PC via the Oculus link cable so that I can play Steam VR games and also so I can play with other people in the room who can spectate without the horrible lag that casting introduces (esp in pacey stuff like BeatSaber).
I was waiting for Nvidia 3000 series cards to arrive to upgrade my venerable but dependable R9 280x and... well, we can all guess how that went for me .
The old card can still handle 1080p for most things I want to play (although not at high frame rates).
Ideally I my plan is to maybe play some VR stuff on the 280x with the quality dialled down until I can get a new GPU or maybe sell a kidney. I realise R9 280x is 'not supported' but I had assumed it would still work but would just be a bit 'sub-optimal'.
However, I've had zero luck with it. My link cable is in place and the USB test says my speed is 1.1Gbps. The Quest shows up in the Oculus Windows app without issue.
However, if I try to launch anything I get a black window on the PC and absolutely nothing on the Quest. Nothing, nada, zup, bupkis... If I try something on Steam VR it can see my headset but not my controllers and it keeps telling me to wake the headset even though it is awake.
Also, if I try to buy an Oculus app it tells me that I don't have touch controllers (I do, the app says they're connected).
Drivers look good, cable being connected is recognised (as allow / deny pop-up appears), the Quest shows up correctly under Windows drivers and, as I said before, the Quest is recognised by the Windows Oculus app.
Am I just barking up the wrong tree here? Will this simply never work at all or is some part of my install borked and, if I put the effort in, I'll be rewarded with something that at least works. I can't find an answer to this anywhere.
I can get a (supported) GTX 970 for £160 to tide me over but I don't really want to pour more GPU money down the drain than I have to.
Answers on a postcard please. Particularly interested in anyone who has got this working on an older, unsupported AMD GPU.
Cheers
Cheers
