@MoNkeE
Hmm is it that easy? You know, when I fiddled around with ALVR I encountered similar problems with the video Stream encoding so I never bothered to look for another 3rd-party solution. And you are absolutely right about spending 300 for a used and already out of date card, especially when a r9 200 series was considered very VR-ready back in the days. Of course newer hardware is better hardware but I really dig the Virtual Desktop idea.
So thank you a ton, I will test it especially under the aspect, if the image resolution is comparable or higher than the tweaked 1600 possible via Link. It may turn out to be even better, as my 5gh router is close to the living room with enough space while my workstation with LAN cable is busily humming in my work room, with not as much free space.
have a great x-mas with your family
