Help on upgrade
18 Sep 2007
Hey hey,
I curently have an ati 2900 that does ok, but I was thinking about upgrading so I could run dx10 games at max settings with some decent framerates. I only use small monitors for gaming so I don't need huge resolution settings but I do run a hdmi output to my tv (which the current 2900 doesn't have sound for... ).
Current setup is:
q9300
asus p5q3 deluxe
artic cooler pro
4gb 1333mhz ddr3
520W power supply
So basically, should I get:
1) 4870x2 (which also means a new power supply)
2) GTX 280 (again new power supply)
3) 4870 Toxic (no new power supply and I could get a blu ray drive + maybe new monitor)
Any other thoughts advice would be appreciated (max budget is £500) and I mainly play HL2 based games, Farcry 2 and CoH.
Thanks,
Dave
considered waiting for the revised gtx280 if its not already out?
or
looking at the gtx260 216 core as well?
