help on what psu i will need
19 Jan 2012
hi am not too savy on hardware and could do with some help i have just bought a new desktop for £400 without a power supply so am after whats the best possible option with cheap in mind??? for the system heres the beef
coolermasteer HAF 912 gaming case
4 custom red L.E.D fans
asus rampage ii extreme motherboard
intel core i7 950 @ 3.06ghz
g.skill rip jaws 12gb DDR3 ram (1600mhz)
coolermasteer V8 cpu cooler
2 x Nvidia 8800gtx
SLI X-FI sounds blasteer sound card
dvd rw drive
samsung blueray disk drive
and also same goes for a hdd best possible cheap in mind? 500gb would do :D
erm hdd is
Seagate 500GB 3.5" SATA-III 6Gb/s Barracuda Hard Drive 7200RPM 16MB Cache
and power supply is
Corsair Memory TX650 V2 650W ATX Enthusiast Series
is that enuf info or?
he said 650w would do it he said its down to the quaility of the psu?
advice on them? :)
quality of the PSU is obviously important but so is the amount of power it can hand out
I had issues with a 650W PSU and SLI
PSU.. yeh 750W is the safer option.. the PSU is a VERY critical part of your computer so dont skimp here
HDD... spinpoint is fine
not saying this is 'sound' advice but currently running an clocked FX-8120 and a clocked 4870X2 with water cooling system on a 550W OCZ Z-series, which is silent as hell and hasn't had a hiccup under maximum load with this system. also keep in mind Bulldozer is supposed to be a massive power consumer and so is the 4870X2.
read some reviews ages ago when the 8800GTX first came out (had GTS model) which put the maximum power draw of the whole system at around 315W, keep in mind that is entire system draw so that includes hard disks, processor, memory, fans and so on, can't imagine another GTX drawing much more than ~150W with two six pin connectors and PCI-E slot, so would say the 650W Corsair would be upto the task. :)
Aye, my friend used to run a pair of 8800GTX cards in SLI (with an overclocked i7 920 system) off a Corsair TX 650W (version 1) PSU and it was running fine. Though if you are buying new I would personally spend the extra on a 750W as it will give you so much more choice in the future for upgrades (and they don't cost too much more).
The Seagate Barracuda HDD is a good one, but don't worry about SATA2 or SATA 3 - with these mechanical hard drives SATA3 is unnecessary as even SATA2 bandwidth isn't being saturated at full load - SATA 3 is basically used on them for marketing, not performance.
