HELP: One core very high temp 50% Load?
27 Sep 2010
On my i9 7900x one core is showing showing the load on "Core Temp" at 50% this is idle? and because of this the temp is over 50c idle. The temp difference on idle again between the core that has 50% load on it and the lowest core is about 18c difference 52c - 34c just in case someone wants to know which cores core 0 34c & core 7 52c
