looking at this pic could you suggest a better airflow etc etc, curently sits @ max 70oc under heavy load.
would like to drop allot if possible, a few extra notes , 2 of the top fans have shrouds on the inner side the other fans don't, theres a vent in the lower of the case for a 120mm fan.
the case sits under an open 10ft by 3ft shelf ( only obstruction is the rear wall )
just wondered if anyone else has a similar setup and have experimented with the best setup and could suggest any improvements, regards the waterloop and components i have tried every possible combination and the current one was the best.
thanks
thanks
