Well mine will hit 80c at stock under a dual tower k2 cooler with x2 2350 rpm fans. The best way to stress theese chips is normal use. Theyre not designed with tests such as p95.
@the op, the 0x124 bsods your getting can be down to lack of vcore, or to low on chipset voltages such as ioa/d and system agent. The 1.7v reading your seeing is likely initial cpu input voltage. This is what the cpu uses when booting into windows. I have mine on 1.88v as any lower and it fails to boot.
