hello all and welcome to my thread before i start this is my 1st amd sytem i have every tried overclocking so please bare with me
so to begin with iam building a rig for my mates dad atm the rig is only half complete still wait on a cpu cooler to turn up and graphics card the specs are as follows
X2 550 BE (on stock cooling atm)
Asus M4A88TD-V EVO/USB3 G880 (really dont have a clue about this bios)
2x2gb of 2000mhz G-skill Ripjaws
HD4870 512mb
corsair TX650w
WD Black 1tb 6gb/s
2x 22xDVD-RW
so far ive managed to ulock the cpu to a quad core and got it 3.4ghz prime stable for 30 mins and hasnt gone over 66 degrees with stock cooling but i feel it has got a lot more left in it as i have only alted the multi and if i run the ram over 1600mhz it will crash just before gettin into windows
the settings are atm
Vcore 1.416v (whats the highest i can safely go on this ?)
FSB ? 200mhz (altering this 5mhz higher and it will crash)
multi x17 (cant get it any higher than this 17.5=3500=crash)
ram 1600mhz (cant seem to get the rated 2000mhz in any off the options?)
vram 1.65v (is this to high as it stated at 1.6 but it wont go over 1440mhz at that voltage)
loadline calibration cpu enabled
loadline calibration cpu/nb enabled
C1 off
AMD cool'n'quite enabled (would this be better off ?)
these are the only settings i have changed as iam a bit clueless about the rest any help would be helpful would like 3.6 really but its not for me and i think the guy who is going from a P4 with 256 of ram wouldnt really notice a extra 200mhz but as ive said iam sure i can push more out off it as i think it was great bundle CPU/MOB/RAM for less the £240 the whole rig has only cost £460 just trying to see how much bang for buck i can get out off it as a little side project so any of you amd oc'ers can you help this little sad intel boy
many thanks in advance
HD4870 512mb
corsair TX650w
WD Black 1tb 6gb/s
2x 22xDVD-RW
C1 off
