Help: Overclocking E8400
16 Jan 2009
Hi Guyz,
I am ausing E8400 E0 With Asus P5Q-E Motherboard.
I have Overclocked it to 4GHZ.
But the problem is that, my system passes Stress tests like Prime95 and OCCT.
But during routine work,sometimes it freezez, i mean no cursor movement, still display, no hard Disk activity Light. So i have to restart my PC manually.
It also happens during Gaming.
Here are my Bios Settings.
Guyz Plz Help me, and suggest some solution.
Thanx in Advance.
Best Regards.
I think you're applying far too much voltage to the SB. I have mine set to either auto or 1.2v at the most. (p5q pro)
You shouldnt also need 1.4v on the NB unless you are going for a massive overclock with all your RAM slots filled. 1.3v - 1.36v should be more than adaquate.
Leave PCIE SATA voltage alone, you dont need to adjust that. PPL voltage is also way too high. You only want 1.6v max for a 45nm CPU.
I got Corsair Dominator 4GB (2*2) 1066mhz ram.
What PLL and NB value should i try now?
Thanx.
