Hi, Im having bit of trouble overclocking my e6300, i had a target of 3Ghz in mind; is this possible with a DS3 and corsair value ram?
The Max ive had stable is at 2.73Ghz (390x7) at just over stock volts
ive read the ds3 overclocking guide but it says o put vcore at 1.45v which is a bit high i think. My temps are around 45ish idle using tat.
can anyone give me a step by step guide (as im a bit of a noob) on what todo next?
edit: i also have a Akasa AK-961 cooler(would like better but low on funds)
Thanks ben
Thanks ben
I am currently tring 2.59ghz with mine. I have OCZ Gold GX DDR 667 running at 740mhz 5-5-5-15 1T @ 2.1v, Abit AB9 .
Upped the RAm voltage and loosened the timings a tad now stable
Seems my CPU/RAm cant do the extra 10mhz
