help overclocking my system
6 Jan 2007
Hi All,
I have the following setup and cant seem to overclock it
Gigabyte M68MT-S2 motherboard with AMD Phenom II X4 840 3.20Ghz processor.
I have looked in the Bios but as soon as I change CPU Unlock to enabled it will not load windows 7.
What settings do I change in the Bios
Also EasyTune 6 does not change the speed it just reverts back to standard
Any help would be great
Cheers
Dex
Help overclocking
Hi Guys
I cant find anything in the BIOS
But can use easytune6 now
I have changed from 200 going upto 215 now
but when i run CPUID in shows a core speed and its jumping all over the place
It seeps the core speed and the vcore go up and down
is this normal ?
Driving me mad
Help guys
Dex
Help Overclocking Phenom II x4 840
Hi Guys
just got my watercooling sorted
I can change my voltage now but have a few questions and need help setting it
Bit of info first
VCore = +175
Easytune5 info
CPU 3328.00mhz
FSB 208 mhz
Ration x16
memory 1385mhz
Sys Temp 32c
CPU 20c
What would you change to make to CPU run faster and also what do you think of the temps
Any help would be great guys
Dex;)
