I have had a quick go at overclocking my X2 4200+ and have managed to get it to 2420Mhz prime stable using multipler x11 fsb220 cpu volts 1.1 ram volts 2.8 and hyperthreading x4. Temps are around 45 deg under load so should be able to go a bit further but I'm a bit stumped now as if I up the fsb anymore windows will not load up.
Could someone who's managed to clock there cpu past 2.4Ghz on air please post their most stable setting for a clock higher than this so I can give it a try please.
many thanks
Edit:-
My memory is 2 x 1GB corsair XMS3200 TwinX btw and I'm using an Arctic Cooling Freezer 64 Pro HSF.
Please someone help I'm a complete overclocking noob
many thanks
Edit:-
