Hi recently upgraded to a dual core system. I cant seem to get the chip past 3.3ghz.
Heres the spec;
Intel Bad axe 2 motherboard
E6700
4gig ram
520 corsair HX psu
8800gts oc
250gig hdd
tuniq tower
At the moment im at 330 @ 10x multi temps are 30idle 45load everything set to stock volts. orthos stable (24h)
Thing is as soon as i up the fsb it fails orthos instantly, ive tryed uping the cpu voltage and the mainboards voltage does the same..
Im happy with 3.3 but if i can do 3.3 on stock it should have some more it in.
surely 330fsb isnt this boards max..
Any advice would be grateful
Heres the spec;
E6700
4gig ram
520 corsair HX psu
8800gts oc
250gig hdd
tuniq tower
