Plus both of you guys have low Asic cards so that means yours needs more voltage to be stable than my higher Asic card.
That means you will need to throw more voltage at it to get stable clocks, so you can indeed whack it up to 1.3 volts if needed. Max i can go up to is around 1.231 volts.
