Until tonight I had a happily running 6600 / Bad axe 2 combo.
But
Whilst trying to get it to pass orthos as 3.6 I read about an item that should
be disabled in the maintance Bios.
So I moved the jumper changed said item saved and came out - reset
jumper to normal and.....nothing it wont post.
I get all the fans spin but No signal / No USB keyboard / Mouse lights and
no HD light - which was always on with the older BIOS I am using.
If I disconect the monitor I get the no signal message up - plug it back and I
get a blank screen.
If I move the jumper again it still wont let me back in the maintance Bios.
A bit stumped now...
I have plugged keyboard / mouse into my old system and both are fine.
Anyone got any ideas / suggestions
Thanks
But
get a blank screen.
Thanks
